I tried it on a different PC with a different browser. But without success.
Could you send me a link to this scene (via PM if the scene is not public)?
This is the scene I am working on.
Each bathroom has a link to 2 more bath variations. They should open with the camera view of the same bath in which you choose another style. There is a WC in the ground floor and two more bathrooms on the upper floor (Badezimmer and Elternbadezimmer).
Hi @tim,
This link worked for me: http://architektur-visualisierung.build/DATA/citrus3d/baudirekt_sv155k/final/haus/index.html#autoplay&view=WC It started from the WC view.
Maybe on the other computer you had opened exactly this visualization in the past, and the previous version of the walk.min.js
is still in the browser cache?
@Wojtek, from the WC it works because the first camera in the new scene is the WC. But I can not address the other cameras in that scene.
The other views also work for me, for example:
http://architektur-visualisierung.build/DATA/citrus3d/baudirekt_sv155k/final/haus/index.html#autoplay&view=Aughöhe%20158%20cm (in Firefox you can enter a link using non-Latin characters and spaces, but when you copy/paste the link it’s changed into a universal ASCII encoding)
If it’s some caching issue the easiest solution is to bundle the scene once again, and upload it to your hosting once again. Then, replace walk.min.js
, however it’s important that you do it before opening the new version of the scene for the first time.
Wouldn’t pressing ctrl + F5 to reload the website clear the browser cache sufficiently?
Yes, it will, good point.
In my heavyweight solution I assumed that a link had been already sent to the client, so it may be also in the client’s browser cache.
@wojtek is there a way to connect scenes which are stored locally? My client wants to use the scenes offline. I guess they have to set up a web-server?
@tim does the client have a local Shapespark application running? If so, you can access the local scenes via http://localhost:5000/scenes/SCENE-NAME, You should be also able to connect local scenes using such addresses
You mean without a Shapespark installation?
No, this will require installation.
Thank you @jan. I will test it.
