Hi guys.
here’s another project of a house this one is one of the biggest we have developed. Hope you like it.
Comments and critics welcome as always
https://gaesvr.shapespark.com/3dmpchs/
Well, I was able to walk through the entire house including the stairs. Good Work.
If I had any suggestions,
- I might work on some of the lighting. Some rooms seem a little (emphasis on the little) bit dark to me.
- I would also suggest adding a light probe to some of the rooms to kind of liven up some of the materials.
- You cold also add one (light probe) to the front of the house to add a little reflectivity to the cars. You might also need to adjust the materials for the cars so that they look at little more metallic.
Again, good job.
Thanks a lot for your suggestions.
i’ll work it out, and also you are rigth i didnt add a probe to the main facade so theres not reflection on the objects.
Grettings
