Because i baked lighting and i don’t want to fix in SU , update and spend baking lighting again. How can I fix texture size in Shapespark?
You can replace the texture in the Shapespark editor Materials
tab. You need to unlock it first with the padlock icon.
But i can’t fix texture size. I wanna reduce the texture size.
Maybe you can tile it in Photoshop and then replace the image?
If Tim’s idea does not work in your case, you would need to update the model and bake again, it is not possible to change the UV mapping and keep the lightmaps.
yes. i got it. thank you!
