Hello.
Does anyone knows a good way to make water in shapespark? i’ve done this attempts and i dont think they look to well.
So if anyone knows a better way plss let me know, i’ll be good for everyone
Grettings!!
You can add a bump map (don’t overdo) and reflections/metallic to the surface.
Hello, thanks so much for your reply.
Have you done one ? could you show me ?
Plss
For example, a fountain here: San Miguel 2.0 by Model: CC-BY Guillermo M. Leal Llaguno has:
opacity 0.48
base color 0.3, 1, 1
bump scale: 0.02
bump texture:
@Antonio_Perez, hola Antonio
revisa este link
https://all360.shapespark.com/sala_de_pruebas_pileta/#mobilehi&vrhi&help&autoplay
(mira al final del link para elevar la calidad de la escena)
mira la foto con los settings
aplica este bump
espero que te sirva.
MUCHAS GRACIAS HERMANO.
lo voy a robar y les enseño los resultados
you can badly see the ploygonal geometry.
I think it’s not a matter of geometry but of the bump texture resolution. In this case the bump texture is rather low-res, but using a high-res one you will obtain smoother result.
Perhaps in the future Shapespark will have a version of presentations for stronger graphics cards?
webgl-water
Great demo! Thanks for sharing.
Our main focus is to achieve as high quality as possible on an average device because the viewers of an online architectural visualization are not necessarily 3D artists or gamers, so they are not expected to have a powerful GPU. But of course, we are also considering adding features that may be conditionally enabled only on higher specced machines
Yes, there is this problem.
