Hi All,
I am getting lines in my textures. It looks like two textures side by side but in fact it is only one. Does anyone have any ideas of why this is happening?
Thanks in advance
John
Hi All,
Thanks in advance
John
I guess it might be the lightprobe issue
It could be also lighmap issue if the walls are split into separate objects along one flat area. Make sure that all continuous flat parts of your wall are in the same mesh
Hi Anton / Kuba,
It was a light probe as
Anton suggested. I added another light probe in the kitchen. I have attached an updated image.There is still a major problem. The reflection from the living room windows is coming through the living room walls onto the concrete floor in the hallway. Is there any way to contain reflections in a room?
John
Hello John, does the floor material have the ‘Parallax correction’ checkbox enabled in the Materials
tab? It looks like the window reflection is not placed where the window actually is. Could you upload this scene and share a link here or to support@shapespark.com?
Hi Jan,
It had parallax correction enabled.
I figured out the problem. I just needed to add another light probe in the hall.
As you said before each texture takes the reflection from the closest light probe. The closest light probe to the hall had been in the living room.
John
