Dear ,
When we click to screen it spot we near to object any setting so it spot apart to some distance from object.
Dear ,
No there is no such setting. You can stop the movement any time by looking around with a clicked mouse, but if you won’t stop it, the camera always stops 70cm from the object.
CAN WE INCREASES 70 TO MORE LIKE 200 CM PLEASE SUGGEST WAITING FOR REPLY.
WE ARE TRY ONE MODERN ART GALLEY IT STOP WE NEAR TO MODEL , WHICH CONFUSE VIEWER .
Thanks in advance
Yes, we can expose such setting. Do you have a deadline for this project?
by the way, you could use a trick to put fully transparent surfaces 2m from the art pieces that would prevent the camera from moving closer. Is this feasible?
Thanks please suggest some robust way…
tell how can i change settings
or you send …
WAITING FOR REPLY
its urgent
Have you tried the solution that Jan has suggested? I’d say that If the art gallery has regular shape it should work pretty robust.
Could you please post a link to the scene (or send via PM if it’s not public) so that we could take a look and give you a more detailed advice?
i will share , but its is possible directly in settings…
you must give this option
reply please… we are waiting it important
As a temporary solution, please put a following body-end.html
file in your scene directory (in Documents\Shapespark\SCENE_NAME
https://drive.google.com/open?id=1n0HTEBgU3G5AZ7H1rg6ftGQweWhlKiYK
wao you are awosome … thank you so much for you support
