OK. Here’s the detailed explanation of the feature I was discussing with @tim about.
Starting from version 1.7.6 Shapespark allows to force importing multiple objects from a 3D file (eg. FBX, DAE) as instances of a single Shapespark object type.
If an imported object name starts from __NAME__ (any NAME preceded and succeeded by double underscores) it is imported as an instance of an object type named NAME . So, if in your 3D modelling tool you name the objects as:
__Chair____Chair__.001__Chair__.002
they will be imported to Shapespark as 3 instances of an object type Chair.
This helps for import workflows which doesn’t support object instancing via the 3D file itself by allowing to pass instancing information in object names.
