There is any way that I can create a template with textures already configured, and then just update the template with a different model in SketchUp colored with the same textures as the template.
A way that: If I use the same texture, I don’t have to reconfigure… and than just bake the scene.
I’m trying to speed up the process.
In the Shapespark folder, you copy a project folder and rename it. In Sketchup you then don’t create a new scene for the export to Shapespark but update the scene using the scene name you gave to the copied folder. That’s it.
Thank you Tim.
Where can I find the Shapespark folder?
You can find Shapespark’s project folders in your local user account under Documents/Shapespark/
