boa tarde meus queridos!!! essa ultima versão do shapespark 1.12.0 estou tendo problema em exportar projetos mais pesado.quanto á projetos mais leves estou conseguindo exporta. É algum problema que estar tendo???
Hi!
There were rather no changes in 1.12.0 which would cause such a behavior, so it may not be related to this particular version.
Do you have problems exporting a model from SketchUp or from another 3D tool? Could you send us a problem report using the “Help & Support” tab of the Shapespark application? The report will include application log which will give us more information about the error.
tambem nao consegui exporta do sket para o shapespark, exportou faltando algumas paredes e blocos.
Shapespark renders polygons only when you look at them from the front. So, it sounds like some of the polygons in your SketchUp model are not oriented correctly: they are oriented to the camera with their back faces, while they should be oriented to the camera with their front faces.
Please see this video showing how to fix face orientation: https://www.youtube.com/watch?v=kuBYX9vW1qg
