Hello!
Is there a way to disable the bump, reflection, and roughness map on mobile, so we only use the base color because it improves the performance on mobile a lot while keeping the desktop version loading full texture?
Thank you!
Hello!
Thank you!
Unfortunately not. A not very convenient way to achieve this would be to make a separate mobile-dedicated copy a scene (in Documents\Shapespark folder) and remove light probes from this copy.
