is it possible to import all maps of a material (Color, Roughness, Metallic & Bump) in any way? I am only able to get the base color map working. Can’t find much about this topic.
Best regards
Best regards
Hi Paul,
it is not possible by default. You have to create a JSON script that can do this for you.
You can search for “JSON” and “map import” to find some further information on the forum.
Tim
@Paul if you need to control other parameters of the materials with texture maps you can add them in materials properties in Shapespark editor. They don’t get imported with the 3d model. You have to setup each material manually.
