Materials Opacity problems (materials disappear)
I found a bug that materials with opacity disappear if you move the angle with a keyboad or mouse.
For example, the material in a red box disappears if you move a little bit. And if you move to other angle, it happens same but the other way around.
At first, I thought that it was material’s problem but it wasn’t as it happens to other material as well.
I would highly appreciate if anyone could help me with this issue.
Thank you in advance :slight_smile:
Hello,
This is because Shapespark uses an order depended approach when rendering transparent objects, but such order is not always possible to establish correctly. Order of transparent objects is rendered differently due to the position of the camera. That’s why objects are overlapping when you are moving. The only way to avoid it is to make one of the overlapping materials not transparent.
