Wonder if there is any easy fix for this? Ive attached a screenshot of the issue im having, essentially im using a HTML pop up to show off an information board, but where the meetings overlay is placed (top left) it interferes with the information.
Is there any easy way to move the overlay to the bottom left for example? Or the HTML pop up to the centre?
We would like to address this problem by increasing the priority of the HTML popup, so it opens on top of the meeting status (the meeting status becomes invisible as long as the HTML pop up is visible). Do you think such approach is OK in your case?
Sorry to be a pest with this, but is there any chance of this getting fixed for Monday? My client has the meeting on Monday so would be great if its good to go by then.
Also, another small issue with the meeting overlay is that it interferes with the branding on the top left of the screen. My client hasn’t picked up on this so not a huge issue for now, but maybe something for your team to have a little look into if its a quick fix!
you could write a js-script to remove the css classes of the html element which is the meeting overlay.
If I remember correctly the css classes to remove should be “ui-top” and “ui-left”. Then you can add new style attributes to place the element where you would like it to be.
@Ling, thank you for your reply. Ive not delved too much into changes the js-script. Is there any sort of online guide to follow for this so I can give it a go?
Thats incredibly helpful, thank you very much. The client will appreciate being able to have a meeting and their branding on show as well, ill give your solution a go.
Thanks again for your help, I sincerely appreciate it.
Daryl
