Is not a inappropriate question! On the contrary, it is a very important issue that I have also had a hard time defining.
I share my estimations about it and the logic behind it
The works we do are actually unique and customized interactive web pages, that makes them a customized product and that has its cost.
The service we provide is a very specialized service because we combine: 3D models from BIM software (Rhino, blender, revit, archicad, sketchup, 3dMax etc) with rendering with Shapespark (and other software), plus programming, plus color or texture, change interactions, and more.
In addition, it is very likely that you should make
Story script depending on the product or service that your client wants to expose through the platform, if it requires a virtual fair, or a stand, or a virtual store, or an art exhibition, or a sale of house or apartment, or simply show a final design to a client. Each one of the possibilities has coincidences but at the same time they have different story scripts to emphasize different needs. That story script must be proposed because only you know all the technical tools.
If you add a HTML+JS specialist to generate more sophisticated interactions that increases your price.
I will not go into detail on how to get the cost per hour because that depends on the structure of your company (staff or team) but it is important to mention that if you are fully dedicated to this, your production hours (the hours actually worked to generate a tour) should cover all the others.
Having mentioned the above, the production hour of a tour is around 70usd/h in my case. Depending on the complexity and the interactions elaborated, the cost of the tours range from 800usd to 5000usd or more. This should be understood as a parameter, the relationship with each client is unique and you can negotiate long term processes or modified standard tours that will vary considerably your costs and the final price.
I hope to contribute with you and others as frankly as possible.
Best regards
Jorge
ESPAÑOL
Al CONTRARIO, es un tema muy importante que también me ha costado mucho definir.
Comparto mis estimaciones al respecto y la lógica detrás
Los trabajos que realizamos son en realidad páginas web interactivas únicas y personalizadas, eso las convierte en un producto a la medida y eso tiene su costo.
El servicio que brindamos es un servicio muy especializado porque unimos: modelos 3D de software BIM (Rhino, blender, revit, archicad, sketchup, 3dMax etc) con renderizado con Shapespark (y otros programas),más programación, mas interacciones de cambio de color o textura y más.
Además, es muy probable que debas realizar un guión de historia dependiendo del producto o servicio que tu cliente desee exponer mediante la plataforma, si requiere una feria virtual, o un stand, o una tienda virtual, o una exposición de arte, o una venta de casa o apartamento, o simplemente mostrar un diseño final a un cliente. Cada una de las posibilidades tiene coincidencias pero al mismo tiempo tienen guiones distintos para enfatizar necesidades diferentes. Ese guion de historia debes proponerlo porque solo tu conoces todas las herramientas técnicas y sus posibilidades de uso.
Si ha esto le sumas un especialista en HTML+JS que generé interacciones más sofisticadas eso aumenta tu precio.
No voy a entrar en detalle de como se obtiene el costo por hora porque eso depende de la estructura de tu empresa (personal o equipo de trabajo) pero si es importante mencionar que si te dedicas plenamente a esto, tus horas de producción (las horas efectivamente trabajadas para generar un recorrido) deben cubrir todas las demás.
Dicho esto la hora de producción de un recorrido ronda los 70usd/h en mi caso. Dependiendo de la complejidad y de las interacciones elaboradas el costo de los recorridos rondan entre los 800usd a los 5000usd o más. Esto debe entenderse como un parámetro, la relación con cada cliente es única y puedes llegar a negociar procesos de largo plazo o recorridos standar modificados que variarán considerablemente tus costos y el precio final
Espero contribuir contigo y con los demás de la manera más franca posible.
Saludos
Jorge
