hey,
I was having an issue where all the reflective elements like mirrors and metal are appearing black on this device while it runs and looks fine on other accounts/devices.
Usually this problem is solved by
clearing browser cache
trying incognito login or alternate account login
switching from chrome to other browsers like firefox
but none of these are the solution in this case
additionally, we have also tried updating the walk.min.js and other associated files on the host side and updating the scene thats built on a newer version of shapespark.
Desktop - Windows 10 Pro - 64bit
Processor - Intel(R) Xeon(R) CPU x3430 @ 2.40GHZ 2.39GHZ
RAM - 32 GB
DirectX runtime version - 11.0
Graphics - GeForce 9400 GT - 4095 MB
attached images of how the scenes are appearing
Any inputs regarding a possible solution would be helpful
Do you have access to this device? If so, could you open Chrome developer tools (F12), go to the ‘Console’ tab and check if there are any errors reported when the scene is loading?
If it happens only on this single device, a likely reason can be a graphics driver issue, perhaps there are newer drivers available?
Is this some old version of the library? The 2nd error is no longer be present in the newest version. Could you test also with Shapespark hosting? It always uses the newest version of the library.
Yes, This was the older version of the library but after updating to the newer version the 2nd error has been resolved. updating the drivers will take time since I don’t have access to the device. if that doesn’t fix the issue we will be sure to try Shapespark hosting as well
I’ll update this thread if that resolves the issue.
