Scale UVs of video material
Please assign the mp4 movie to [Base Color] in [Material].
When I upload a scene after changing the Scale value in UVtranceform, the movie material flickers or otherwise does not display well when viewed on an iPhone or iPad.
Do you know the cause?
Hi!
Could you share with us your scene so we can take a look how does the flickering look like in your example? If the scene is private would it be possible to send a link directly at support@shapespark.com?
Mostly due to webgl1 compatibility we need to clamp the video textures which causes edge stretching when scaling uv. We might be able to add possibility to repeat video textures that each dimension has a value of the power of two (32, 64, 128, 256, 512 etc)
