Hey there, is there a way to show the views tags while using the vr mode? I need it to teletrasnport from one apartment to another. Currently using the oculus quest
The view menu is a part of the HTML interface, and HTML elements aren’t rendered in the VR mode. Would the Change view extension with a trigger placed somewhere in the scene work for you?
Not sure if this works on Oculus Quest but works on Oculus Quest 2 - if teleportation is the only issue try buttons B and A - they cycle through all the views (no visible tags though). Also - buttons X and Y - make you go up and down:-)
I think ill be adding the change view extension trigger for this. Thank you so much
