Hi. We have some trouble with a plant and a curtain in a scene we are working on. The curtain has some opacity and the plant uses a png with opacity. This leads to a strange display problem:
Do you see this only on some type of device? On my desktop the plant leaves are correctly detected as cutout textures and do not show this problem. There is much more subtle render-order related flickering on leaves edges, but the plant is correctly rendered in front of the curtains.
I tested it today on another PC. No clipping. Went back to the other PC and tested in two different browsers. No clipping. So the problem solved itself.
