hi any information about max 3d file size can be used in shapespark
There are no strict limitations on the 3ds max or any other input 3D file size. For a model to work well on mobile devices, the geometry shouldn’t be too large, less than 3 million triangles is recommended, but this is not a strict limit and Shapespark will allow your to import much larger models.
hi
can you give me example
thanks
For example geometry in this scene: 3D walkthrough demo room by Shapespark has 2.4 million triangles.
You can check the number of triangles at the bottom of the Shapespark editor Objects tab:
