About route settings
I would like to know how to set up a camera route when moving between views.
What determines the movement between the start and end points?
Is it possible to specify the movement (route) between the two points?
Thank you in advance.
In the Shapespark editor Camera tab there is an Auto path setting:
When this setting is disabled the camera switches between views in a straight line, the shortest path that connect the two points. When the Auto path setting is enabled, a path is selected that avoids passing through the 3D geometry (walls etc.), so it is not a straight line, but more like a walking path of a human.
