Hello !
Here’s the issue :
It happens with a few objects in my scene. I tried to isolate shadows on those and putting the lightmap resolution to 150 (and up to 8 lightmaps) but doesn’t get better. Any idea?
Thanks !
Hello !
Here’s the issue :
Thanks !
Most likely, the meshes of these objects are not smooth and contain duplicated vertices and edges. What 3D tool are you using? If 3ds Max, try welding vertices/edges of the meshes.
Hi Wojtek, I use Sketchup, unfortunately haha Do you know of a similar technique with Sketchup?
Thanks !
Indeed, it’s way better ! Thanks for the tip !
