Hi there !
I have two walls. One red, one white. When I run the lights calculation, the white wall turns slightly red.
An idea ?
Hi there !
An idea ?
It’s a colour spill from the “global illumination”. If that is the correct term
If the slight red on the wall is undesirable, bake the scene with the red wall textured with a neutral colour, then change the material back to red for the upload. I think that could work.
haaaa that’s clever
Why thank you
Only issue with that workaround is the red won’t be visible in any reflective surfaces.
while waiting to find better, it is a very good method thank you!!
Let us know if you find a better way
