Hello, Is there a way to change de default location of the Shapespark Documents Folder to another place, like another drive for example?
Is it possible to add this option?
Thanks.
Thanks.
It is possible, you need to place a file called config.json in the C:\Users\<YOUR-USER>\AppData\Roaming\Shapespark directory. With the following content:
"scenesDir": "c:\\Users\\<YOUR-USER>\\Desktop\\Shapespark"
Please modify the path in this file to point to your desired scenes directory. Use double back-slashes \\ between directory names.
After adding this file, restart Shapespark. If you don’t see any errors, you can move your existing scenes from Documents\Shapespark to the new location.
Hello,
The config.json file was already present in my case. When I added your line of code and saved it, and restarted Shapespark, it says that config.json file is corrupt. Please remove it and start again.
Can you please let me know a fix for this.
Thanks.
Hi, could you share on the forum or send us your config?
Hi @jan
I experienced the same problem when I tried to change the path.
This is the original one:
“devices”: [
“CUDA_GeForce GTX 1080_0000:41:00”
I added your lines
I also tried it with additional brackets but always get an error message.
The JSON format requires each config entry except the last one to have a trailing comma, so you need to add a comma after the ]:
“devices”: [
"scenesDir": "e:\\Shapespark"
Works now!
Thank you
Thank you @jan,
It worked for me too !
Good day,
Does the above work exactly for Windows 11?
if not
How do i change the default directory on Windows 11
Smarty
Yes, it works for Windows 11 as well.
Wojtek,
After a new installation of SHapespark on Win 11, when i seach for config.json i dont find the file
Help
Smarty
I think i’ve got it.
I had to make a change to my configuration for the program to create one.
After doing that i found it, and made the changes for the new directory.
Now all seems to work as i wish
Smarty
Hello, can this config change to default with the program update?
@luiza, no, changes to the scenes folder made in config.json are preserved during application updates.
