every time we switch the view shapespark goes back to the original default position of that view Can I change the view while keeping the camera position?
I don’t think it can be done with regular Shapespark operations, is it possible to solve the above problem with “Scripts”
Do you mean you would like to keep camera rotation when changing views? (so only camera placement is moved from point to point without affecting camera angles?)
If yes then it’s not possible with regular Shapespark functionality.
