I keep getting this error on self hosted bundles.
There is no clear direction on what could be causing this. Thoughts?
This seems to be related to the recent update.
I tried copying a webwalk folder from a previous build and it attempted to load. It got a bit further, but then started bombarding the view with 404s
Hi. It looks like you are facing a known problem with Brotli compression. We are working on it but as a workaround you can disable Brotli compression on your webserver or remove a file 3dassets/br.buf
from webwalk folder.
I am facing the same issue. I am getting “corrupted huffman code histogram” in the console log and not able to play the scene on my own hosting.
@nishantambekar, have you tried to apply the workaround from the Tomek’s post above?
Yes. Deleting br.buf worked for us
