Hi.
I would like to know if it is possible to create lights (position, type, amount of strength, used IES.file) with a JSON file during export from 3DS Max. Or do I have to export the lights themselves?
Regards, Tim
Hi.
Regards, Tim
Hi @tim, you can do it using a following JSON file format: GitHub - shapespark/shapespark-extras-json: A JSON file format that can be used to import additional properties to Shapespark.
Thank you, @jan Jan. Will this create new lights or do I first have to prepare them in Max?
If a light with a given name does not exist in the input FBX, it will create a new light. If the light exists in the FBX, it will update it.
Thanks for clarifying this!
