Hello!
I am wondering if there is any way to add more icons for the sprite triggers?
I could use an object type with a custom design temporarily, but i need it to be facing the viewer all the time.
Any help is appreciated, thanks!
Hello!
At this moment it is not possible. This triggers use a small subset of icons from the Font Awesome 5 free set: Find Icons with the Perfect Look & Feel | Font Awesome
Are there icons in the Font Awesome 5 that would be suitable for your project? We could extend the included set, but we wouldn’t like the selection to be too large (for example including all 1500 icons would be a problem).
If Font Awesome icons are not suitable for your project at all, supporting other icon set would be rather difficult. Perhaps we could support rotating custom triggers to always face the camera, but we would need to check how doable it is.
Unfortunately we need custom trigger designs due to clients requests…would be great if we can create a custom trigger (a small plane that faces the camera) that allows us to upload a png
Hi, Is there any update on adding custom png icon for triggers? which rotates as per camera in the scene?
We still don’t have this feature
+1 for this request.
Is there any workaround on how i can make the geometry icon rotate as per camera? (like how normal button face camera)
Also will you’ll be implementing this feature in near future updates, let me know if there will any updates here.
We plan a release this week that will allow to configure objects to rotate and always face the camera.
Could we place images on those objects (surfaces with images of people for example) so that they are always looking at the camera?
Yes, any object can be configured to rotate, also objects with textures. The requirement will be to orient these objects along the Y axis in the 3D modeling program before exporting to Shapespark.
Thanks @jan,
This can also be applied to the glow around light sources. It will always be aimed at the visitor.
I would like to use the https://fontawesome.com/icons?d=gallery&m=free and would need a Film and a Pause Icon, how can I setup this in Shapespark?
To use icons outside the set offered by Shapespark you’d need to use a custom trigger with textures containing the icons.
In the particular case of film and pause icons you can also use textual trigger with Unicode characters (you can copy-paste the characters from this post):
🎞⏸however, the result may vary in different browsers, so it’s best to check how they look in the most common browsers.
In the next release of Shapespark, we’ll extend the offered icon set with film and pause Font Awesome icons.
I can not find a Textual Trigger, do you mean a HTML Trigger?
I mean a regular extension trigger, but using a text instead of an icon:
Ah understood. Works very well now! Great, thank you Wojtek!
