Hello -
We’re having issues with .FBX import as the maps/model is having a lot of errors on import. See attached examples.
Does anyone have experience working/solving this problem?
Hello -
Hi!
What 3D modeling tool does your model come from? Have you taken a look at our list of typical export issues? For example, you can find the list for 3ds Max issues here:
https://help.shapespark.com/hc/en-us/articles/360009141717-Importing-a-3D-model-from-3ds-Max
This is from 3DS Max -
We’ve looked at the documentation and haven’t found a solution yet - wondering if this is a known issue
Looks like some issue with exporting or importing object transformations to/from FBX format. Would it be possible to send the 3ds Max model (eg. via wetransfer.com) to support@shapespark.com ? Just the model file will be enough - textures are not needed.
if you are using 3DS max, then dont mirror geometry or objects…rotate them. Items flip along their axis. It made for a lot of extra remedial work for me in Max to convert mirrored objects retrospectively…so start a new habit and rotate.
