The error in the attached image occurs on the Shapespark login screen when going through the company network.
The PC terminal can access HTTP and HTTPS via proxy.
On the other hand, the same PC terminal is accessible via a non-company Internet connection
The connection will be available.
As a workaround, 「HTTP_PROXY=http://…」 would like to set the environment variable
How do I set this up? Should I put the “HTTP_PROXY” part in some configuration file? Or should I define it in the user’s environment variable?
In the case of the user’s environment variable, the address ends with a number.
Is it OK if the address ends with a number?
