I have a export error showing as attached.
Does anyone have any idea how to fix this issue?
Does this error occur always for the same texture file? Does your export create a new scene, or update the existing 8042024 scene?
No, the texture file varies, different texture maps everytime.
And it occurs when I update the scene, not a new scene.
Sorry for the delayed reply.
Does it happen only if you update the 8042024 scene? Have you tried exporting the scene under a new name, and then updating this new scene? If it works, it means there are some file permission issues in the 8042024 scene directory. Could you locate the the 8042024 directory in Documents\Shapespark and check if some of the files in the directory are marked as read-only (you can check the file permissions in the Properties dialog accessible through the right mouse button context menu)?
Hi, thanks for your reply.
I just re-installed all software including windows and it solved the issue.
I assume it was caused by file systems of Windows.
Thanks for your help anyway.
