Hello,
I havea problem with a scene. I can’t access it via the editor anymore, I can’t export the sketchup to that scene (creating a new one is fine though), I can’t upload/bundle. Every time it’s a “failed to generate web textures”. Last thing I did was cancel the baking because of some last minutes changes to make to the sketchup.
Here’s the editor.log (last lines) :
[25/11/2020 11:54:21] - info: Started. Command line: C:\Users\chris\AppData\Local\Shapespark\app-2.0.1\Shapespark.exe
[25/11/2020 11:54:21] - info: Loading configuration from file: C:\Users\chris\AppData\Roaming\Shapespark\config.json
[25/11/2020 11:54:21] - error: HTTP server socket timeout
[25/11/2020 11:54:21] - info: Starting HTTP server and waiting until it is available
[25/11/2020 11:54:22] - error: HTTP server socket timeout
[25/11/2020 11:54:24] - error: HTTP server socket timeout
[25/11/2020 11:54:25] - info: HTTP server started
[25/11/2020 11:54:25] - info: Checking for application updates.
What can I do? I need to rebake it for today and I made too many modifications in the editor to start over again…
Thanks !
