Here is a link to my first model: https://ntxdave.shapespark.com/carwash/
Yes, the model has some problems but it is an old model that I was using for testing Shapespark (I currently just have the trial). Through another thread, I have already learned how to fix problems with some missing faces (I need to go back and fix some things in my SketchUp model - I used some stuff from he 3D Warehouse) but now I have some questions for moving forward:
Is there a way to change the model/scene name (both before I upload it and after uploading it)?
When you look at the first view, it is way too light. I to the Lights and then selected Sun (which is the first light on the list) and tried to reduce the Strength to 1. I then went to Bake and clicked on Preview but do not see any change. How do I get this changed?
I have added a Point Light to the Support Equipment room and when I preview it, it looks fine. However, when I go to the Top view, the room is still dark and I cannot figure out how to correct that dark room.
Is there any way to add a background (i.e. HDR)?
When I render/Bake the scene, I have the Samples set to 200 and it took about 8 hours to finish the 4 cycles of the baking process. Is this normal?
When I bake, should I use CPU or CUDA (CPU: Intel Core i7-4700HQ CPS @ 2.40GHz and the CUDA: GeForce GTX 765M (Display))?
OK - These are my questions for now. I am sure there will be more in the future (before my trial expires). ![]()
