Hi there
Does anyone know why is this error coming out when i select grass material ? Material needs to have uv mapping from 3d software or has to be free from it ?
Hi there
Hi @Inm3rsivo
Grass material uses a default texture for color and for noise. To use texture in a material, the object with this material should have UV mapping.
Please, make sure that objects on which you would like to apply the textures have some texture applied in a 3D modeling program, otherwise UV mapping might be missing for these objects and the replaced textures will not be mapped correctly.
