Hello!
I was wondering if it’s possible to change the help menu to other languages, I don’t mind changing it manually in the bundled files if you could tell me what should I change. Or if you could add more languages options in future updates, that would be great
The default index.html (containing the help text among the whole UI HTML) resides in C:\Users<USER>\AppData\Local\Shapespark<VER>\resources\webwalk\
If you place this file in the scene directory the scene will start to use its own “custom” index.html, which allows you to introduce per-scene customizations to the UI.
To localize the help text open the custom index.html in a text editor, eg. Notepad++, and simply replace English captions with the desired language.
