Help: Two HTML Label
Hi!
I would like to know if there is a possibility of having two html labels open at the same time on the screen?
normally when you open an html label screen, when you click on another one that is open it is closed.
I would like to know if it is possible to keep 2 html label open?
thanks
This is not possible with the built-in HTML Label extension, so it would require programming custom HTML pop-ups.
If your pop-ups have content that doesn’t require HTML and can be presented as images, you could create the pop-ups as 3D objects in the scene, and use two Switch objects extensions to toggle their visibility independently.
Hi @wojtek, can we place a video on a pop-up surface?
Yes, however the video will be playing also when the pop-up is not visible.
hello woj
thank you so much
