sometimes,i want to show some Additional information,such as html5 websit,images,flash link, or another project link in html laber.how can i make it happen?
This can be done with an HTML Label extension configured in the Extensions panel of the Viewer tab. There is a video tutorial showing how to set it up: INTERACTIVE Walkthrough on the WEB | Shapespark for Sketchup - YouTube .
thank you,i’ll try it
when i test in offline,it works fine. Once i upload the sense , i found most browser would intercept the html link.include browser in iphone and wechat. It only can play in IE browser.how can i make it work on other brower and iphone?
in ie browser,when i click the botton,it show what in picture.and i must click it,and it will work fine.
active this option,i can open it directly without any tips
it seems that it identified as unsafe script in Google Chrome.
i can’t find any tips or options in iphone brower,so it means that the script can’t load on iphone??
Shapespark scenes by default use encrypted HTTPS protocol . Browsers do not allow sites that use HTTPS to load external content using not encrypted HTTP protocol.
A recommended solution is to use HTTPS links for external content.
You could also load a scene using HTTP protocol: http://lidingxing.shapespark.com/liushuibieshu/ but it is much better to use HTTPS.
thank you,http works fine in iphone browser and wechat
Would it be possible to have an Open URL trigger inside a standard HTML trigger? I want to display information about the product before they are taken straight away to the website, and it’s a bit difficult to do inside a small sphere.
Never mind, I figured it out.
