1- How can I put an audio with a personal description, a brief description of the space or some specific object, how can I do that?
2- I want to know if there are other sources of audio besides this which is the only one that has worked for me. (https://www.youtube.com/audiolibrary/music)
3- this site has a spectacular audio system, how can I use this site to enter their audios? (Background Noises • Ambient Sounds • Relaxing Music | myNoise ®)
If you have your own audio file, you have to put it on some web hosting first. For example, if you use WWW hosting service to host a website, it could be used to host audio files as well. Then you can use the address of the hosted file as the URL property of the Shapespark Audio extension.
This site seems to generate the audio procedurally, so it cannot be used directly. I think you would have to buy an audio file version of the selected noise and use the file as in point 1.
Currently, there is no volume control. Are you thinking about controlling the volume during the scene creation or about offering volume control to the viewer?
Thanks for the information. For now, if the audio file you are going to use needs volume adjustment, it needs to be done in the audio file itself using some audio editing software.
Hi , I’m following the method of using my own audio file upload to my own hosting server. The audio url is only appear sound on editor mode but after I’m uploaded my scene to cloud. My audio is not working.
Are you using HTTPS (not HTTP) protocol for fetching the audio? It’s necessary when you open the scene with HTTPS protocol. Otherwise, the audio resource is blocked.
When you open a website (in this case a Shapespark scene) using HTTPS protocol, the website resources such as scripts, audio, video, must be also fetched with the HTTPS protocol.
