Hi! I have a question
All the furniture should disappear from the display off scene I made. And when you press the display on scene again, objects should appear.
But now, when you press off and then on scene again, other floors and objects that you put in the switch object option appear together. The picture below is about that error. Is there any way to fix this??
Hi! Currently, the switch-object and hide in views can’t work like you want them to work. You can emulate this desired behavior using custom JavaScript, but this will require proficiency in JavaScript. We are working on finding a way to make this scenario work easily and without breaking any other scenarios.
