I am making a floor material picker.
If you change the floor material with the material picker, the floor pattern will change.
It will be repeated. I want to prevent the floor material from repeating.
The program is based on the following program.
viewer.setNodeTypeEditable(‘wall’);
viewer.setMaterialEditable(‘brick’);
var brickMaterial = viewer.findMaterial(‘brick’);
var nodes = viewer.findNodesOfType(‘wall’);
for (var i = 0; i < nodes.length; ++i) {
viewer.setMaterialForMesh(brickMaterial, nodes[i].mesh);
