Is there anyway to keep Vray/Corona materials when synce 3dsmax model to SS?
All materials become solid in SS editor.
Should I export to FBX first?
The plugin supports only certain properties of Scanline and V-Ray materials.
check out this link for more information: https://help.shapespark.com/hc/en-us/articles/360014324137-Import-a-3D-model-from-3ds-Max
If you’re using Corona materials, you can explore converting your Corona materials to Vray for a smoother transition.
Hey Magda,
Shapespark is used 95% of the time to visualize architecture in some way.
For architectural visualizations, Corona Renderer is the render plugin of choice. It’s easy to use and delivers great results. So you can assume that 90% of 3DS Max users work with it.
Based on this fact, it would be a huge step forward for Shapespark users if you would support the export of Corona materials.
It would make the work of most Shapespark users much easier.
Maybe you could think about adding this to your list of features.
Tim
