I need to apply a switch object, but I need to be able to isolate lights so that each object has independent lighting. Is this possible?
Hello, could you clarify what you mean by independent lighting? When you enable ‘Isolate Shadows’ for each object in a Switch Object setup, the objects won’t cast shadows on one another but will still be illuminated by all the lights in the scene. However, if you’re looking to have completely different lighting setups for each object, this is not possible.
