hi guys
we can see there is instances numbers here
how take advantage for this instance system to duplicate objects
hi guys
This is the number of objects of a certain object type (objects sharing the same name). Object instances help to manage object-related properties for many objects at once, for example to hide all the objects of the given type in a certain view.
As far as geometry is concerned, Shapespark automatically detects objects with identical geometry, and this is performed independently from object instancing. So, if you have identical objects in your 3D modelling tool, you don’t have to do anything to enforce geometry sharing.
