Hi , i was wondering if shapespark would recognize copyed object as instance if changed the scale of the objects inside 3dsmax , knowing that iam following the naming structure , or the scaling would damage the instance recognition and will consider every scaled up object as an individual object ?
Scaling an instance won’t prevent it from being recognized as an instance.
BTW, are you using the Shapespark exporter for 3ds Max or intermediate file-based workflow? If the former, then you don’t have to use the __NAME__suffix naming scheme - the exporter automatically recognizes 3ds Max object instances.
