Hi
I’m encountering an issue when adding the “Hide Triggers” extension to the “Multi Trigger” extension. Each time I attempt this, the user interface panel turns completely white
(please see the attached screenshot).
The “Multi Trigger” extension itself works fine—it successfully toggles the “Hide Triggers” extension on and off as expected. However, since the UI becomes completely white, I cannot save the scene. After restarting, the “Multi Trigger” setup is lost, and the issue recurs.
Could you please provide assistance or suggest a workaround for this issue as soon as possible?
Thank you for your help!
Thank you for adding this report! Indeed there is a bug and we have a fix for it ready. We should be able to release it in our cloud editor soon (maybe this week). It will also be released in the next desktop version of Shapespark, but it might take some more time.
Unfortunately I don’t see an easy workaround for this issue which you could apply immediately.
Would it be OK if, for now, the fix was only available in the cloud editor?
Thanks! It should be fine to have it in the cloud editor for now.
Hope it will be ready within the next few days.
Please let me know as soon as it’s done
The fix for this problem is available in the cloud editor
Please let us know if you encounter any other problems.
