Is it possible to add a material name under, in or above a sample?
Being able to select color options is pointless if people don’t know what the option is called.
No, this is not possible. The material picker spheres are rendered in 3D, and positioning flat or 3D texts of different lengths on top of them would be quite an undertaking.
What should be possible is to display a message with a selected material name in a corner of the viewer when the user selects a material. For example: ‘Gray marble selected’. It would require naming the materials in a user friendly way. Would it be an acceptable solution for you?
if not for @Random for me it would!
But please as an electable option.
Yes @jan that would be an acceptable solution. But as @tim said, please make it an electable option.
Please see this example: 3D scene
This scene uses the following custom body-end.html file to show a name of the selected material. You can place this file in your Documents\Shapespark\SCENE_NAME\ folder to have the same functionality.
Hi Jan,
Could you explain how do this. It is not working for me.
John
@JOHN open a raw version of the file in your browser: https://gist.githubusercontent.com/wrr/822605c2bb581e75bb2cecfc72fe27d5/raw/2a3423b9ee46ebbcecb6d719ee794595f3c8242c/body-end.html, right click and select Save As, select a folder with your scene (it is in Documents\Shapespark\SCENE_NAME) and make sure the saved file is called body-end.html (by default a browser should suggest this name). Does it work?
Yes, body-end.html can be uploaded only in the Standard and Plus plan. This is because custom HTML allows to brand the viewer and such branding is not available in the Starter plan.
A post was merged into an existing topic: Materials on material picker
Hi Jan,
I have copied your body-end file into the main folder of my scene but I still do not see any names come up when selecting the different materials. These are the files I have
I think I found my error I needed to put it in the actual folder in my documents. I have done that and rebundled but still see no names. Any advice or assistance would be greatly appreciated.
Hi!
Example script is using depreciated API function.
viewer.setMaterialForNode has been replaced with viewer.setMaterialForMesh
Here is updated version of the script with correct function call:
<style>
#banner {
position: absolute;
top: 30px;
text-align: center;
font-size: 3em;
width: 100%;
z-index: 10;
visibility: hidden
</style>
<div id="banner"></div>
<script>
(function() {
var messageId = 0;
function hideBanner(bannerElement, messageIdArg) {
return function() {
// Hide the message only if it wasn't replaced with a new one.
if (messageId === messageIdArg) {
bannerElement.style.visibility = 'hidden';
function showMessage(message) {
var bannerElement = document.getElementById('banner');
bannerElement.textContent = message;
bannerElement.style.visibility = 'visible';
messageId += 1;
setTimeout(hideBanner(bannerElement, messageId), 4000);
viewer.onSceneReadyToDisplay(function() {
var setMaterialForNodeOriginal = viewer.setMaterialForMesh;
viewer.setMaterialForMesh = function(material, node) {
setMaterialForNodeOriginal.apply(this, [material, node]);
showMessage('material: ' + material.name);
</script>
