Model made with Corona
Good afternoon. How do you usually work when using a model made in 3ds Max with Corona? I modeled and textured everything using the standard 3ds Max material, but most of the assets I used are set up with Corona Renderer.
Shapespark doesn’t support the Corona material system, so you’d need to convert the materials to another system first. If you have V-Ray installed, it has a material converter built-in. Otherwise, you may look for a third-party material converter that supports Corona system as the input, and V-Ray or Standard as the output.
