Multi trigger option: can I choose more than one audio trigger?
Hi everyone.
I think the multi-trigger option is great!
Today I wanted to turn off several sounds when leaving a room using this possibility but I came across the surprise that I can’t choose more than one audio within the multitrigger action list!!! I found this very strange!
Can I choose more than one audio for multi-trigger action, yes or no?
If the answer is no, please make it posible, if the answer is yes, I have a bug to report.
On another hand, that selection of actions within the multi-trigger window should be more friendly, it’s very uncomfortable because it’s very small plus, the line only displays the list of actions to be arrived when you choose the only one visible!
Regards
For now, this is how it works: you can add more than one Video Texture Control and Objects Switch, but all other types can only be added once. We’ll look into whether this can be changed in the future.
Thank you @magda. I got it!
It’s not common for me to want to turn off several sounds at once, but this is what I needed this occasion.
I solved by placing a multitrigger for every sound in every space.
I hope that later you can handle several sounds with the same multitrigger because it is much more comfortable!
Greetings.
Jorge.
Yes, I agree it would be useful.
Thank you for your feedback! :slight_smile:
