hi,
is this possible,
i use multi trigger for HTML label and Material picker, so that i can have one trigger to access both extension.
now, may problem eh, how can i add another trigger to hide and show the set of multi triggers that i made.
If your trigger (the text that is seen on the picture) is an object, then you can use the Switch Objects extension to hide/show it. If it’s a sphere or sprite trigger, then that could also be done, but with the use of more advanced techniques using the script extension (this would require you to know some programming and JS language).
I hope this helps.
