Open and Close Door with trigger in Shapespark?
Hi, Are there any ways to make the open close Door works in Shapespark ?
Thanks !
You could use Change view extension, and have one view with open doors visible and the other with closed door visible. Such views can be hidden from the view menu with the Hide from menu checkbox.
This would work with one doors, but would become problematic if you have multiple doors that you would like to control in such way.
thanks for your reply , I see this is the only simple way we could do
Hello Jan,
Is there a way to configure the doors to open and close with a trigger (Hinged doors at 90° angle and sliding doors to move at a specified distance). Can you customize them with CSS for your scenes?
Please add this features to Shapespark. I’m sure a lot of users out there will appreciate having it, rather than having to walk through a door all the time.
At this moment the only way to have doors that open in Shapespark is to have two version of the doors in a 3D model - opened and closed, and use Swtich objects extensions to switch between them.
CSS is suitable only for modification of the 2D UI of the viewer, it is not useful for customizing 3D behavior.
