Optimization and shared avatars between two versions of a scene (Meeting mode)
Hello Shapespark team,
We strive to deliver high-quality 3D content using Shapespark, but many of our clients report overheating or performance issues on their devices when visiting some of our more complex scenes.
We are considering creating two versions of the same scene: a full version and a “light” version optimized for less powerful hardware.
The idea would be for the user to start in the main version, then be redirected to the light version if performance issues are detected, but still remain in the same Meeting (with avatars visible across both versions).
Is this currently possible with Shapespark’s Meeting system? Could two separate scenes share the same meeting space / avatars?
I’ve already tested the “switch object” feature to create two versions of the same building within a single scene, but the results were not convincing in terms of performance and organization.
Thank you in advance for your help!
Best regards,
Unfortunately, there is no other solution than the Switch Objects that would keep the meeting running.
Could you share the scene with us, so we analyzed the performance issues on our end?
